Part Naming
cory_isaacson
Member, Developers Posts: 43 PRO
I am using FS to generate multiple parts in a single feature (sometimes 20 or more). They come out with default names, like Part1, Part2, etc. I understand that part naming is not possible right now with FS. Is there a way to do this with the API, after the parts are generated? If so, how can I figure out what PartN is so I can rename it (such as MyPartN)?
Yep, we definitely want a pure FS solution for naming an other metadata in the future.
For now the process will involve the following steps:- (optional, might make querying easier later) In FeatureScript, call setAttribute on a part created with an attribute of e.g.
{ "myPart" : "top" }or{ "myPart" : "side" ~ i } - In the API, get deterministic ids for specific parts. This will involve calling Part Studios: Evaluate FeatureScript API with a function returning
transientQueriesToStrings(evaluateQuery(someQuery))), wheresomeQueryis either:- A query for the specific part you want (possibly a
qCreatedBy("someOperation", EntityType.BODY)), OR - If you did step 1, a qAttributeFilter for the specific attribute (e.g.
{ "myPart" : "top" }) set for the part in step 1
- Use the Parts: Update Metadata API (or, for multiple parts, the Parts: Update Part Metadata API) to set the name of a Part based on its deterministic id.
In the meantime, let us know if you encounter any issues with the strategy outlined above!
6 - (optional, might make querying easier later) In FeatureScript, call setAttribute on a part created with an attribute of e.g.
Is this still the state of the art? Is there an FS solution yet?0
There is no FS solution yet, but we are closer -- a number of changes are in the works, that when combined, will make it possible to set part names and colors in FS.Ilya Baran \ VP, Architecture and FeatureScript \ Onshape Inc2
Bumping this thread. Is this still the best way? Very much looking forward to a FS solution.0
The state is still unchanged but we're very close to releasing this ability.Ilya Baran \ VP, Architecture and FeatureScript \ Onshape Inc2
