What wrong with my variable? (new to Onshape)
guy_payeur
guy_payeur Member Posts: 2 ✭✭
I am testing Variables an tried to use it on a dimension that measure the distance between construction lines with several constraints:
Like you can see, I am not able to use the variable SecW, it is red colored.
You can have a look by yourself here : https://cad.onshape.com/documents/c11a0a79541ebdc42d826896/w/edecf49e09b47f2d44ddf365/e/eb8919f3c9e66a722d132d9b
The dimension is Driving the distance and when I type a number the drawing adjust itself like expected.
Thank you
  • konstantin_shiriazdanov
    you can't use variable in feature that is located in feature tree before variable defenition
