Trouble applying a fillet or chamfer to this simple feature...
rick59
Posts: 6 ✭
Having trouble with this...please check Public Document CLCSC Fin Tube and look at Fillet 3. The outline is there, but cannot get it to actually create the fillet. Same thing with chamfer.
Any tips would be appreciated...
You've got four parts visible, @rick59, and they overlap. If you hide all parts but 'part 1' you'll see that the fillet worked as expected.Paul Chastell
TVP, Onshape Labs5
TVP, Onshape Labs5 -
Many thanks Paul! Looks like I forgot to Merge All with the initial extrude and the Pattern! That fixed it!0
