Adjust line thickness in Drawing mode
Hello all,
Is there an option to adjust the line thickness in Drawing mode? see example:
philip_thomas Member, Moderator, Onshape Employees, Developers Posts: 1,381
@jan_willem - Line thickness is determined by the drawing template.
The templates we supply are consistent with the standards specified (ANSI ISO etc).
If you want to override these standards, export the drawing template to any standalone 2D editor and make any changes you want prior to reimporting into Onshape
Here are detailed instructions - https://cad.onshape.com/help/Content/templates-custom.htm
Philip Thomas - Onshape5
Well done.
