Adjust line thickness in Drawing mode
jan_willemjan_willem Member Posts: 5 ✭✭
Hello all,
Is there an option to adjust the line thickness in Drawing mode? see example:
  • jan_willemjan_willem Member Posts: 5 ✭✭
    edited August 2017
    Fantastic! I will try to customize the template to my wishes.
    regards Jan-Willem
    philip_thomas - Creating a new template was not necessary. Scale 1:3 set to 1:1.
    Result: On the screen still a fairly thick line. Export to PDF; Line thickness fine when opened in Acrobat Reader.
    @jan_willem - Exactly, increase the ratio of the size of the part to the (fixed) line weight.
    Well done.
    Philip Thomas - Onshape
