Can you model parts or assemblies in context of other assemblies?
james_french
Member Posts: 4 ✭
Can you model parts or assemblies in context of other assemblies? For example, make planes or dimensions for parts in relation to other parts in an existing assembly?
https://cad.onshape.com/help/Content/in-context.htm
I create a lot of pipe and if I was to make a sub assembly with 2 fittings say with a slider mate and pipe between them the ICE looks at their position in the sub assembly, not the top assembly.
I make my sub assembly with the fittings and mates only and then add my piping in last in the top level assembly.
Just make sure you never manually move the ICE part. Always move the part it's associated with and update the context.
