Broken line in DXF for laser cut in place of a bend
daniel_humburg
daniel_humburg Member Posts: 5 ✭
edited August 2017 in Community Support
I wish to have parts cut in thin sheet metal on a laser.  I intend to replace bends done with a brake with a broken cut line (stop-start, stop-start) to make the part bend preferentially on the line, and by hand.   I've generated my sheet metal models and flat drawings.  Now I need a DXF with the "strop-start" line type to replace the bend line, which does not show up in the DXF.  I suspect that there is some way to edit the DXF in software such as Adobe Illustrator or others.  However, since the bend lines don't show in the DXF any additions or edits I might do would be less accurate than the original model.   Is there any way within Onshape to create a drawing modification that would show as my intended stop-start line type over the bend lines so that the DXF will include the perforation cuts for my bends?   I'd like a 50 % cut as a starting point so perhaps cut 1/2 inch and skip 1/2 inch.
D. Humburg
  • daniel_humburg
    Helpful answers.   If I can figure out featurescript I may be able to add the broken lines for these cuts.
    Lana, is there a preferred viewer for DXFs?   Can I edit the DXF directly to add the broken cut lines as a layer?
    DSH
  • daniel_humburg
    Thank you.  I've downloaded DraftSight from Solidworks, which seems to be a very capable editor for DXF and DWG files.  I was able to create my own line type for the perforation cuts I want in place of bend lines in that layer.  Next question will be if that layer is "hidden" from the CNC laser or if it can be toggled on to create those cuts.  Perhaps I will need to edit in those perforation lines onto the basic outline.   I'll ask the engineer at the custom fab shop about that.
    DSH
