How to loft / fill airfoil shape across curved wing shape
sean_magee_saxton
Member Posts: 3 ✭
Hi all,
Trying to create / modify a design for a hydrofoil board.
I have a profile generator which I used to bring in airfoil shapes, and the keel extrusion was easy as it does not get narrower at the base.
I cannot figure out how to loft or fill from the foil shape along the main wing, as any attempt with various settings seems to fail to generate properly. I have sketched the profile of the wing, and want the airfoil shape to taper down across it to almost nothing at the end.
Looks like you could create that hydrofoil board with a loft or sweep feature.
Could you share the document?Un saludo,
Partner de PTC - Onshape Averigua a quién conocemos en común0 -
There are a bunch of public custom features that do this type of thing.
Also - check out the custom features page - www.onshape.com/customfeatures.com
and this one in particular may help
https://cad.onshape.com/documents/4bf18c75321ea2c8c2ea770d/w/978aece63f59e09169309756/e/b319e7a87bba701e3e02a0fa
Good luck!
Philip Thomas - Onshape0
