Make Part from an Assembly
Colm_Rev
Member Posts: 9 PRO
I,m having a bit of an issue when I develop a BOM (Using Google Sheets) from an assembly.
Within the main assembly is a sub-assembly.
This sub assembly is listed in the BOM as multiple parts. (Which I don't want)
I read there is no option to exclude a part from the BOM.
To overcome this I was hoping to make a part file from an assembly.
I cannot see how this is done or if it can be done.
Anyone have a workaround so the assembly is just a single line in the BOM
Thanks
Colm
Thanks
Colm
Ok, there are more than one question in your post. I recomended to post each question in a different post
BOM in Onshape still need some improvements, but I will try to explain that part later.Colm_CP said:
If all the parts in the assembly are connected, you could:- create a new part in context from the assembly
- Transform with the option copy in place all the parts you need
- Create an union boolean feature with all the parts
Un saludo,
Partner de PTC - Onshape Averigua a quién conocemos en común0 -
@emagdalenaC2C
Thanks, that's a great work flow! Got me out of a pickle!
emagdalenaC2C said:Ok, there are more than one question in your post. I recomended to post each question in a different post
