Make Part from an Assembly
Colm_Rev
Colm_Rev Member Posts: 9 PRO
I,m having a bit of an issue when I develop a BOM (Using Google Sheets) from an assembly.
Within the main assembly is a sub-assembly.
This sub assembly is listed in the BOM as multiple parts. (Which I don't want)
I read there is no option to exclude a part from the BOM.
To overcome this I was hoping to make a part file from an assembly.
I cannot see how this is done or if it can be done.
Anyone have a workaround so the assembly is just a single line in the BOM
Thanks
Colm
  • emagdalenaC2i
    edited August 2017
    Ok, there are more than one question in your post. I recomended to post each question in a different post
    BOM in Onshape still need some improvements, but I will try to explain that part later.
    If all the parts in the assembly are connected, you could:
    1. create a new part in context from the assembly
    2. Transform with the option copy in place all the parts you need
    3. Create an union boolean feature with all the parts
    Un saludo,
  • APD
    APD Member Posts: 40 PRO
    @emagdalenaC2C
    Thanks, that's a great work flow! Got me out of a pickle!
