Adding Corner Reliefs
justin_m_
justin_m_ Member Posts: 3
What is the best way to add reliefs to the perpendicular corners of a sketch (or an extrude derived from the sketch ?
I have sketched a rectangle on the face of a previous extrude.  I then add a new extrude for this new sketch that removes material from the first extrude.  However, this cutout has sharp corners which can not be machined.  I need to add reliefs to the corners, and then specify those reliefs in my drawing.
Thanks
  • justin_m_
    Thanks philip_thomas!  That works perfectly.  And thanks for the helpful video.
