Setting an array of variables
Dylan_Stewart
Posts: 107 PRO
I am working on a project that would allow the user to set any number of variables they choose.
I am trying to follow the small example in the 'Feature UI' section in the FeatureScript guide and need some help understanding what is going on.
I'm thinking maybe something like this
As always, any and all help is appreciated.
Also, a working sample document of the example given in the FsDoc would really help me understand what is going on.
Thank you.
annotation { "Name" : "Variables",
"Variable Name" : ".....", }
definition.array is array;
for (var variables in definition.array)
annotation { "Name" : "My String" }
definition.myString is string;
annotation { "Name" : definition.myString }
isLength(definition.myLength, LENGTH_BOUNDS);
}I'm not sure if something like this is possible. As always, any and all help is appreciated.
Thank you.
Digital Engineering
Hi Dylan!
This is totally possible. Information about array parameters can be found in the following doc under 'arrays':
https://cad.onshape.com/FsDoc/uispec.html
Your code looks good! You need to change the annotation on the array parameter itself, and define the values in the for loop as 'variable.something' instead of 'definition.something'
Here is an example:
https://cad.onshape.com/documents/85ead7e8198b48c695b39b58/w/4fb966357258b36a88ac0430/e/4eb384334534b70122d7481c
Also, if you press the 'parameter' dropdown (the one with the 'p') and click "array parameter" it will autofill a skeleton for you.Jake Rosenfeld - Modeling Team0 -
AH!!!! Thank you! I figured that this would be possible and come to find out I was almost there! Thank you so much @Jake_Rosenfeld
Digital Engineering0 -
No Problem! This functionality actually just came out about a month ago, so if theres any way you think we can improve the discoverability or quality of the documentation, we would love to hear your suggestions.Jake Rosenfeld - Modeling Team0
So I just tried to add an array value to one of the variables and it didn't like that too much...
The value of any variable that is being used as _input_ to a feature dialog will depend on the execution state before the feature in question has run. This is important because otherwise you could create infinitely-recursive or non-deterministic features. #options won't exist until after the feature is executed, so it cannot be used as input to the feature.
What you're trying to do is still possible though. Making a sample now.Jake Rosenfeld - Modeling Team0 -
https://cad.onshape.com/documents/766878ddc7c6ff4dd110628a/w/ed5861e226d4502d66b6c26b/e/bd4aa0c0e865dea9731057b9
Is this kind of what you're getting at?
Watching this thread with interest, thanks chaps.
HWM-Water Ltd0 -
I wanna-play-too!
@Jake_RosenfeldI I just tried to add your feature to my toolbar but OnS reports there are no features to add. If the document is copied first then it works fine. Do you have a sharing permission set that blocks linking directly to your feature?
Cheers, Owen S.
HWM-Water Ltd0 -
@owen_sparks It looks like Jake did not publish a version in that doc, which is why you can't link to his Featurescript. The copy operation puts the Featurescript into the `Start` version of the new doc, which is why that works.
Best,
Mike0 -
Good information, thanks for looking into it.MichaelThiesmeyer said:@owen_sparks It looks like Jake did not publish a version in that doc, which is why you can't link to his Featurescript. The copy operation puts the Featurescript into the `Start` version of the new doc, which is why that works.
Best,
Mike
Cheers, Owen S,
HWM-Water Ltd0 -
Hi @Jake_Rosenfeld
I think there is a small bug in your FS. It seems to work for all values of an array except the last one.
Examples
(a) I made a feature with 2 options. Option 1 worked, option 2 failed
(b) Straight copy of your doc. The example has 3 options, 1 and 2 work, 3 fails.
Could you give it a poke?
Cheers,
HWM-Water Ltd0 -
@owen_sparks Same... I am trying something like this and it is breaking. I think I know what the problem is but not %100 sure.
Have you taken a different approach?FeatureScript 675; import(path : "onshape/std/geometry.fs", version : "675.0"); const OPTION_COUNT = { (unitless) : [0, 0, 50] } as IntegerBoundSpec; annotation { "Feature Type Name" : "Configurator" } export const configurator = defineFeature(function(context is Context, id is Id, definition is map) precondition { annotation { "Name" : "Option" } isInteger(definition.option, OPTION_COUNT); annotation { "Name" : "Second Option" } definition.secondOption is boolean; if (definition.secondOption) { annotation { "Name" : "Option2" } isInteger(definition.option2, OPTION_COUNT); annotation { "Name" : "Variable arrays", "Item name" : "Variables", "Item label template" : "###name" } definition.mySecondVars is array; for (var variable in definition.mySecondVars) { annotation { "Name" : "Name" } variable.secondName is string; annotation { "Name" : "Array", "Default" : 5 } isAnything(variable.arra); } } annotation { "Name" : "Variable arrays", "Item name" : "Variables", "Item label template" : "###name" } definition.myVars is array; for (var variable in definition.myVars) { annotation { "Name" : "Name" } variable.name is string; annotation { "Name" : "Second Array", "Default" : 5 } isAnything(variable.arr); } } { for (var variable in definition.myVars) { setVariable(context, variable.name, variable.arr[definition.option]); } if (definition.secondOption) { for (var variable in definition.mySecondVars) { setVariable(context, variable.secondName, variable.arra[definition.secondOption]); } } });
@Dylan_Stewart,
Sorry my approach was to add @Jake_Rosenfeld's feature to my toolbar
Wish I could be of more help.
HWM-Water Ltd0 -
Oh, my misunderstanding. I see what you are trying to accomplish now. I was thinking the need for 2 or more driving options.Digital Engineering0
Hi @owen_sparks ,
The options are 0-indexed. So the first option is option 0, the second option is option 1 etc. Just a byproduct of working on code all day
Would it be better for you guys if it was one-indexed?Jake Rosenfeld - Modeling Team0 -
Doh, should have thought of that, sorry. My bad. In my opinion one-indexed would be more intuitive for most users, but you're the Boss, it's your feature.
Write it in Hex if it makes you happy!
Cheers,
HWM-Water Ltd0 -
Brilliant, very useful!"A common mistake that people make when trying to design something completely foolproof is to underestimate the ingenuity of complete fools." - Douglas Adams, Mostly Harmless0
Hi All!
I've added a V2 to the feature that has better error handling and a choice for 0 and 1 indexing.Jake Rosenfeld - Modeling Team3 -
Very nice @Jake_Rosenfeld thank you.
Also love the update feature notification and process. it's clear a lot of thought has gone into this area.
Cheers, Owen S.
HWM-Water Ltd2
