Setting an array of variables
Dylan_StewartDylan_Stewart Member, Developers Posts: 107 PRO
I am working on a project that would allow the user to set any number of variables they choose.
I am trying to follow the small example in the 'Feature UI' section in the FeatureScript guide and need some help understanding what is going on.
I'm thinking maybe something like this
annotation { "Name" : "Variables",
           "Variable Name" : ".....", }
         definition.array is array;
for (var variables in definition.array)
     annotation { "Name" : "My String" }
            definition.myString is string;
     annotation { "Name" : definition.myString }
            isLength(definition.myLength, LENGTH_BOUNDS);
I'm not sure if something like this is possible.
As always, any and all help is appreciated.
Also, a working sample document of the example given in the FsDoc would really help me understand what is going on.
Thank you.
Digital Engineering
    edited September 2017
    Hi Dylan!
    This is totally possible.  Information about array parameters can be found in the following doc under 'arrays':
    https://cad.onshape.com/FsDoc/uispec.html
    Your code looks good! You need to change the annotation on the array parameter itself, and define the values in the for loop as 'variable.something' instead of 'definition.something'
    Here is an example:
    https://cad.onshape.com/documents/85ead7e8198b48c695b39b58/w/4fb966357258b36a88ac0430/e/4eb384334534b70122d7481c
    Also, if you press the 'parameter' dropdown (the one with the 'p') and click "array parameter" it will autofill a skeleton for you.
    AH!!!! Thank you! I figured that this would be possible and come to find out I was almost there! Thank you so much @Jake_Rosenfeld
    Digital Engineering
    No Problem! This functionality actually just came out about a month ago, so if theres any way you think we can improve the discoverability or quality of the documentation, we would love to hear your suggestions.
    So I just tried to add an array value to one of the variables and it didn't like that too much...
    Digital Engineering
    The value of any variable that is being used as _input_ to a feature dialog will depend on the execution state before the feature in question has run.  This is important because otherwise you could create infinitely-recursive or non-deterministic features.  #options won't exist until after the feature is executed, so it cannot be used as input to the feature.
    What you're trying to do is still possible though.  Making a sample now.
    Watching this thread with interest, thanks chaps.
    I wanna-play-too! :p
    @Jake_RosenfeldI I just tried to add your feature to my toolbar but OnS reports there are no features to add.  If the document is copied first then it works fine.  Do you have a sharing permission set that blocks linking directly to your feature?
    Cheers, Owen S.
    mthiesmeyermthiesmeyer Onshape Employees Posts: 115
    @owen_sparks It looks like Jake did not publish a version in that doc, which is why you can't link to his Featurescript. The copy operation puts the Featurescript into the `Start` version of the new doc, which is why that works.
    Best,
    Mike
    Best,
    Mike
    Good information, thanks for looking into it.
    Cheers, Owen S,
    Ah this is brilliant!! Yes, this is exactly what I was looking to do. Thank you @Jake_Rosenfeld
    Digital Engineering
    Thanks @MichaelThiesmeyer.  I've published a version now.
    Hi @Jake_Rosenfeld
    I think there is a small bug in your FS.  It seems to work for all values of an array except the last one.
    Examples
    (a) I made a feature with 2 options.  Option 1 worked, option 2 failed
    (b) Straight copy of your doc.  The example has 3 options, 1 and 2 work, 3 fails.
    Could you give it a poke?
    Cheers,
    @owen_sparks Same... I am trying something like this and it is breaking. I think I know what the problem is but not %100 sure.
    Have you taken a different approach?
    FeatureScript 675;
    import(path : "onshape/std/geometry.fs", version : "675.0");
    const OPTION_COUNT =
                (unitless) : [0, 0, 50]
            } as IntegerBoundSpec;
    annotation { "Feature Type Name" : "Configurator" }
    export const configurator = defineFeature(function(context is Context, id is Id, definition is map)
        precondition
            annotation { "Name" : "Option" }
            isInteger(definition.option, OPTION_COUNT);
            annotation { "Name" : "Second Option" }
            definition.secondOption is boolean;
            if (definition.secondOption)
                annotation { "Name" : "Option2" }
                isInteger(definition.option2, OPTION_COUNT);
                annotation { "Name" : "Variable arrays", "Item name" : "Variables", "Item label template" : "###name" }
                definition.mySecondVars is array;
                for (var variable in definition.mySecondVars)
                    annotation { "Name" : "Name" }
                    variable.secondName is string;
                    annotation { "Name" : "Array", "Default" : 5 }
                    isAnything(variable.arra);
            definition.myVars is array;
            for (var variable in definition.myVars)
                variable.name is string;
                annotation { "Name" : "Second Array", "Default" : 5 }
                isAnything(variable.arr);
                setVariable(context, variable.name, variable.arr[definition.option]);
                    setVariable(context, variable.secondName, variable.arra[definition.secondOption]);
    Digital Engineering
    @Dylan_Stewart,
    Sorry my approach was to add @Jake_Rosenfeld's feature to my toolbar :)
    Wish I could be of more help.
    Oh, my misunderstanding.  I see what you are trying to accomplish now. I was thinking the need for 2 or more driving options.
    Digital Engineering
    Hi @owen_sparks ,
    The options are 0-indexed.  So the first option is option 0, the second option is option 1 etc.  Just a byproduct of working on code all day :sweat_smile:
    Would it be better for you guys if it was one-indexed?
    Doh, should have thought of that, sorry.  My bad.  In my opinion one-indexed would be more intuitive for most users, but you're the Boss, it's your feature.
    Write it in Hex if it makes you happy!
    Cheers,
    leon_pootleon_poot Member, Developers Posts: 87 ✭✭✭
    Brilliant, very useful!
    Hi All!
    I've added a V2 to the feature that has better error handling and a choice for 0 and 1 indexing.
    @Jake_Rosenfeld this is great! Thank you!
    Digital Engineering
    Very nice @Jake_Rosenfeld thank you.
    Also love the update feature notification and process. it's clear a lot of thought has gone into this  area.
    Cheers, Owen S.
