(Sub)Folder sharing
mike_hölschermike_hölscher Member Posts: 110 ✭✭✭✭
Hello,
Is sub-folder Sharing is not possible? The Share option is greyed out when selecting a folder other than a root-Folder.
It seems to be possible on a document level though.
I wanted to give an intern with an Educational Onshape account some persmissions on a specific set of documents in a subfolder, but this was only possible by sharing each document separately.
Is this correct?
Mike
  • nat_mishkinnat_mishkin Member Posts: 3 image
    Correct. Sharing can be specified only at the top-level of a folder tree. Feel free to post a request for more fine-grained folder sharing options in the "Improvement Requests" category.
  • mike_hölschermike_hölscher Member Posts: 110 ✭✭✭✭
    edited November 2017
    Allright. Thanks.
    Allowing to change the Sharing options for multiple documents at one would also do the trick. But that is not possible either. Just looking into a way to edit permissions on a group of files at once, that are not in a top level folder.
