Combining Parts in Assembly
Tarabich
Member Posts: 29 ✭
I'm trying to combine all the beams of this a arm part into a single part, i've trimmed pieces of it to other pieces and it's saying that I can combine them (Boolean, Union).
How would I overcome this to make the arm a single part?
You can use the group mate in the assembly if you want multiple parts to move together. (Might save joining parts in the part studio that would be manufactured as individual parts).
Cheers Owen SBusiness Systems and Configuration Controller
HWM-Water Ltd5
Here's the doc
https://cad.onshape.com/documents/ba146f4fb957ed0abf9e05f6/w/7b5e6e9060483ac5383a7c64/e/188c9d97897dfc6ddcd4cfc9
(Don't mind the ugliness and all, it's just a practice model
) 0 -
I was able to Boolean Union all into one part in your Part Studio Frontsubframe. I had to remove the trim elements in Beam 6. Then select all parts to Boolean worked.
www.accuratepattern.com1 -
Anyone able to combine the lower control arm into a single part?0
I want to have the arm move as a single piece in assembly.0
HWM-Water Ltd5 -
