Tangent edges of FeatureScript Beam can't be hidden on drawing.
Bram
Bram Member Posts: 2
Hi,
I got square beam sections with rounded edges in my model. It seems as if the tangent edges of the beams don't respond to "hide tangent edges" as other direct modeled parts.
Gaby Rochino from support told me to tag @NeilCooke may be he can look into it?
This is the model i'm working on
https://cad.onshape.com/documents/5312821137b69db09c2e912b/w/bff976d1d778d55b2e4bcbe4/e/f404384693047f7b6b05014c
  • PeteYodis
    PeteYodis Moderator, Onshape Employees Posts: 594 image
    I took a look at the drawing from @Bram .  Here is what I see.  No issues from my end.
    Further more, when tangent edges are shown - the drawing view is consistent with the model view.  Am I missing anything @Bram ?
  • PeteYodis
    @Bram Ah... Are you referring to this edge here?
  • NeilCooke
    NeilCooke Moderator, Onshape Employees Posts: 6,099 image
    @Bram - the edges that hide belong to an extrude from a sketch - the sketch uses a sketch fillet which is naturally tangent. Your beam features are using your own custom profiles (using the standard profiles works with hidden tangent lines in drawings). My guess is that there is a rounding error in your profiles. Having taken a quick look, your millimeter profile is set to 4 decimal places, not 3 which is the correct DP for mm profiles. See if you can change your profile definition.
  • Bram
    Thanks @NeilCooke  I'll take a look!
    I haven't made any special changes to the decimal places? Any idea how this got altered? I'll let you know the outcome.
