opBoolean FS Question
papawo
Posts: 206 PRO
if you want to boolean with every solid body of part studio then use
"targets":qBodyType(qEverything(EntityType.BODY), BodyType.SOLID)
1 -
since you want to union opBoolean should have only "tools" and "operationType" filelds in this case -
}]"tools": qUnion[{qCreatedBy(), <code>qBodyType(qEverything(EntityType.BODY), BodyType.SOLID)0 -
sorry, my fault - round brackets for qUnion() and square brackets for argument list
qUnion([qCreatedBy(), qBodyType(qEverything(EntityType.BODY), BodyType.SOLID)])
1 -
thank you for your explanation. it works now.
howabout instead of qUnion , i will use qSubtraction. do i have to use targets?0 -
if you want boolean operation of subtraction type you would have
{"tools": qCreatedBy(),
"targets": qBodyType(qEverything(EntityType.BODY), BodyType.SOLID),
"operationType": BooleanOperationType.SUBTRACTION}0 -
@konstantin_shiriazdanov --i tried the code below but I get an error saying "cannot subtract from it self". can somebody explain pls.
it possibly means that targets contains the body created by sweep among other. so in this case
"targets": qSubtraction( qBodyType(qEverything(EntityType.BODY), BodyType.SOLID), qCreatedBy(id+"sweep", EntityType.BODY))
1 -
it works now! thanks. i get your explanation about the sweep.
in qsubtraction (query1,query2)
by doing this query, it separate the 2 bodies so i can subtract it?
while the previous code , query all the bodies including the body created by sweep hence cannot subtract to itself?
am i understanding this correctly?0 -
yes, looks like this is what happens inside booleanNancy said:while the previous code , query all the bodies including the body created by sweep hence cannot subtract to itself?am i understanding this correctly?
thank you !0
