opBoolean FS Question
papawo
papawo Member, Developers Posts: 206 PRO
Can I do opBoolean without user selecting the "targets"?
  • konstantin_shiriazdanov
    if you want to boolean with every solid body of part studio then use
    "targets":qBodyType(qEverything(EntityType.BODY), BodyType.SOLID)
  • papawo
    edited January 2018
    since you want to union opBoolean should have only "tools" and "operationType" filelds in this case -
    }]"tools": qUnion[{qCreatedBy(), <code>qBodyType(qEverything(EntityType.BODY), BodyType.SOLID)
  • papawo
    edited January 2018
    sorry, my fault - round brackets for qUnion() and square brackets for argument list
    qUnion([qCreatedBy(), qBodyType(qEverything(EntityType.BODY), BodyType.SOLID)])
  • papawo
    thank you for your explanation. it works now.
    howabout instead of qUnion , i will use qSubtraction. do i have to use targets?
    edited January 2018
    if you want boolean operation of subtraction type you would have
    {"tools": qCreatedBy(),
    "targets": qBodyType(qEverything(EntityType.BODY), BodyType.SOLID),
    "operationType": BooleanOperationType.SUBTRACTION}
  • papawo
    @konstantin_shiriazdanov --i tried the code below but I get an error saying "cannot subtract from it self". can somebody explain pls.
    it possibly means that targets contains the body created by sweep among other. so in this case
    "targets": qSubtraction( qBodyType(qEverything(EntityType.BODY), BodyType.SOLID), qCreatedBy(id+"sweep", EntityType.BODY))
  • papawo
    it works now! thanks. i get your explanation about the sweep.
    in qsubtraction (query1,query2)
    by doing this query, it separate the 2 bodies so i can subtract it?
    while the previous code , query all the bodies including the body created by sweep hence cannot subtract to itself?
    am i understanding this correctly?
    edited January 2018
    yes, looks like this is what happens inside boolean
  • papawo
    thank you !
