SolidWorks file failed to translate. SW2015 2.1
squashie
Member Posts: 6 ✭
Desk v4.SLDPRT failed to translate: 55234cbfe4b0d32bdfc01616.sldprt conversion error.
Created at 9:44 AM Today
SolidWorks 2015 2.1 files will not import into Onshape currently. Looks like they changed their format: we're working on a fix. Until then, if you have access to a copy of SolidWorks, you could export the SolidWorks part or assembly as Parasolid (XT) and import the resulting XT into Onshape. It's a reliable way to get data between any two Parasolid-based systems.Paul Chastell
TVP, Onshape Labs5
TVP, Onshape Labs5 -
Thank you. I will try this.0
