Can points be added to an existing sketch with feature script?
ron_moreland
ron_moreland Member Posts: 99 ✭✭✭
edited January 2018 in Community Support
I want to add functionally derived points to a sketch to use as anchors. Can I do this with feature script?
In a way I'm asking to create a custom constraint.
  • ron_moreland
    That's what I thought. Thanks
  • ron_moreland
    BTW, Can you now create arbitrary points in 3 space, or do you need to create multiple sketches?
  • konstantin_shiriazdanov
    opPoint() creates a point in 3d, or you can create a sketch with a number of points by skPoint(), but all of them will be in one plane.
  • ron_moreland
    edited January 2018
    I am having trouble with this code:
       var fPoints is array = [];
            var L = 10.0;
            var CL = L;
            var Rule = 1.0 ;
            for (var i = 0; i < definition.numberOfF; i += 1)
                fPoints = append(fPoints,vector(0,CL*inch));
                CL = CL/Rule;
            skPolyline(sketch1, "polyline1", {
                        "points" : fPoints
    I'm getting "Precondition of skPolyline failed (is2dPointVector(value.points))" in the error window.
    Can you see the
    problem? I suspect I need to declare a vector array, but I don't know how to do that.
    you should use following syntax to generate array of 2d point coordinates
    point = vector(0, CL) * inch;
    fPoints = append(fPoints, point);
    but "point" should depend on loop index "i", or you would obtain array of one the same point "vector(0, CL) * inch"
    and one more thing - to add geometry to 2d sketch you need to initialize the sketch first by means of mySk = newSketch() or mySk = newSketchOnPlane() functions and after the geometry added sketch should be solved by skSolve(mySk)
  • ron_moreland
    Thanks, I just posted this same question as a new post. I'll set it as asked/answered.
  • ron_moreland
    That worked! Why did the point have to be created outside the append?
  • ilya_baran
    ilya_baran Onshape Employees, Developers, HDM Posts: 1,273 image
    It didn't -- the key change is that the multiplication by inch is outside the vector -- otherwise you get a vector with one component a number and one component a length.
  • ron_moreland
    OH! Number != Length... got it
  • ron_moreland
    I just posted another question that I stuck on. Do you have time to look at it?
