Can points be added to an existing sketch with feature script?
ron_moreland
Member Posts: 90 ✭✭
I want to add functionally derived points to a sketch to use as anchors. Can I do this with feature script?
In a way I'm asking to create a custom constraint.
konstantin_shiriazdanov
Member Posts: 1,221 ✭✭✭✭✭
via FS you can't make editable sketches and can't modify existing sketches except deleting. but you can generate by FS a number of 3d points and reference them from the sketch
5
var fPoints is array = []; var L = 10.0; var CL = L; var Rule = 1.0 ; for (var i = 0; i < definition.numberOfF; i += 1) { fPoints = append(fPoints,vector(0,CL*inch)); CL = CL/Rule; } skPolyline(sketch1, "polyline1", { "points" : fPoints });I'm getting "Precondition of skPolyline failed (is2dPointVector(value.points))" in the error window.Can you see the problem? I suspect I need to declare a vector array, but I don't know how to do that.
point = vector(0, CL) * inch;
fPoints = append(fPoints, point);
but "point" should depend on loop index "i", or you would obtain array of one the same point "vector(0, CL) * inch"
and one more thing - to add geometry to 2d sketch you need to initialize the sketch first by means of mySk = newSketch() or mySk = newSketchOnPlane() functions and after the geometry added sketch should be solved by skSolve(mySk)
