Is there an alternative to Alt+Drag on Linux?
aras
Member Posts: 16 ✭✭
On every Linux desktop environment I have used, Alt+Drag moves the window under the mouse. The browser being another window, moves as well, so I can not use this key combination under Linux. Is there any alternative keys, or any plans to switch this over to something else when under Linux?
Box/cross-select is done by simply clicking in free space and dragging. If the user drags left to right, the selection will be a box-select and will select entities that are fully encompassed in the area selecting. If the user drags right to left will do a cross-select and will select entities that partially fall into the area selecting. There should be no need for the ALT key.Aras said:
I believe OnShape uses Alt-Drag to do rectangle selection.JakeRamsley said:Hi Aras,
Can you clarify what you are trying to do? I can't think of any drag operations that we have that are modified by the ALT key.Jake RamsleyDirector of Quality Engineering & Release Manager onshape.com1
Hi Aras,
Can you clarify what you are trying to do? I can't think of any drag operations that we have that are modified by the ALT key.Jake RamsleyDirector of Quality Engineering & Release Manager onshape.com0 -
I just tried alt-drag vs just drag and I saw no difference.Mike Partain aka Spiked3
http://www.spiked3.com0 -
Can you clarify what you are trying to do? I can't think of any drag operations that we have that are modified by the ALT key.Jake RamsleyDirector of Quality Engineering & Release Manager onshape.com1 -
Thanks by for the reply. It looks like I was confused, glad this is not an issue.0
