Combining multiple imported parts into a single "Part Studio"
edward_casati
                    Member Posts: 8 ✭
                    I am using the McMaster catalog for the first time to download pre-made hardware designs, like nuts, bolts, spacers.
When I import a part, Onshape creates a new "Part Studio" tab for each individual part.
Is there a way to combine the imported parts into a single "Part Studio", so I don't end up with a dozen tabs across the bottom of the screen? For example I could have a different "Part Studio" for Nuts and Bolts, another one for Spacers, etc, each one containing several imported parts in one place.
owen_sparks
                            Member, Developers Posts: 2,660 PRO
                    Hi, although this seems like a simple use case I don't believe there is a simple answer to this.
As it stands OS doesn't have an "Import to this existing part studio" function, nor does it have a "move the contents of this partstudio to another existing partstudio". If we're talking assemblies then that's easy, but not partstudios.
As you saw the derive has to derive a copy from somewhere so you can't delete the original tab.
I can think of a workaround of building as assembly of each and then doing an in context edit copy in place to get a PS with one of each in there, but that's a sledgehammer to crack a nut, and all the part properties will be lost, you'll just have Part1, Part2, yada-yada.
If your use case is just to tidy the document then I'd say make folders along the bottom of your document for each flavo(u)r of component and put individual partstudios in those with one component in each studio. When you insert or derive these parts they'll all come in at the origin, which won't happen if they're all spread around in a single studio.
Sorry, that's probably not the answer you're looking for but hopefully good enough for today.
Cheers,
HWM-Water Ltd5
Also worth noting that as of the January update onshape has built in hardware options.
Hp that helps Owen S.
I must be missing something... I can derive' an object, but where do I put the original that I am going to reference? When I 'derived' an object, and removed the original that I derived from, the derived seemed to go away also. I saw a couple of projects that did what I want to do 'by reference' (there was a 'link symbol involved) but I couldn't figure out where the referenced object was stored..
The hardware feature is nice, but it doesn't have the size nuts and screws that I need.... of course. (sigh).
-Edward
I can't find a 'flatten' option anywhere.
A) I download the McMaster part.
b) I 'import' the file by pressing the '+' at the bottom left of the screen.
c) A couple of options are presented, neither of which are 'flatten'. I leave the options alone and proceed.
d) The file gets imported into a new tab, plus a file that just seems like a redundant link to the original file.
No 'flatten'. No way to combine the two parts into a single tab that I can figure out.
(BTW... not a useless thread... there's something missing in the user interface that may be obvious to experienced users, but is not intuitive to us plain folk.)
Cheers,
The 'create folders' answer is a great temporary solution,until something better can be devised. It still isn't the same as being able to import multiple parts into a single parts studio, but it's a good start!
Sure thing.
One other thing I'd recommend is to add a mate connector to the part in your library part studio. Then when the time comes to use the part the connector will come in with it too. Sure they can be inferred from the geometry later but I prefer to have a predefined point that I know is being used each time.
I'm also hoping that in a future version of OS we'll be able to reference mate connectors along the lines of "Derived1.Mateconnector2" to make assembly configurations pretty much build themselves
Cheers,
