Drawing Balloon Label Bug
frank_weeks
Member, Developers Posts: 6 EDU
When inserting a Balloon in a drawing, I type the Label into the dialog and click accept. However, the default Label appear in the balloon instead of the one I entered. I am then forced to edit it (which works fine) to get the one I want. Minor bug -- hopefully quick and easy to fix. Thanks!
- Choose the balloon toolbar button, which opens the dialog.
- Enter your label text into the dialog.
- Click in the drawing to create a balloon in the drawing, which should have that label text.
- Edit the label again and click to create the next balloon, as the dialog will remain open.
- Repeat as many times as you want. When you are finished creating balloons, click Escape on the keyboard or click the green checkmark or red X button to close the dialog.
So the text you enter into the dialog is for the next balloon you create. Thanks!
