Why are my variables not working when set for feature driven pattern
brad_phelan
Member Posts: 85 ✭✭
I have the following profile designed using a variable width
In my custom feature I have tried the following
The profiles are patterned
but the two new sketches don't accept the width variable. Any idea what I am doing wrong?
annotation { "Name" : "Profile", "Filter" : SketchObject.YES, "MaxNumberOfPicks" : 1 }
def.profile is FeatureList;
setVariable(context, "width", 115 * millimeter);
applyPattern(context, id + "sk0", {
"patternType" : PatternType.FEATURE,
"instanceFunction" : valuesSortedById(context, def.profile),
"transforms" : [transform(vector(50, 0, 0) * millimeter)],
"instanceNames" : ["a"]
}, identityTransform());
setVariable(context, "width", 315 * millimeter);
applyPattern(context, id + "sk1", {
"transforms" : [transform(vector(100, 0, 0) * millimeter)],
Optionskonstantin_shiriazdanov Member Posts: 1,221 ✭✭✭✭✭check if the entity that is refferenced by the "width" dimension is internal geometry of the sketch, i would reccomend put a point to the sketch origin and apply a fix constrain to it. then dimension everything relative to this point/ all the external sketch refferences are droped by feature pattern and it is the main problem
5
for(;;;){
setVariable(context,...);
applyPattern(context,...);
it would be nice if applyPattern had an extraparameter
variables of type array of map where variables for each instance could be set.
definition.entities = definition.bodies;
definition.instanceNames = names;
definition.transforms = transforms;
for (var k = 0; k < size(transforms); k += 1)
setVariable(context, "dCharacteristic", .030*(1 + (k*.002))*inch);
applyPattern(context, id + ("pattern" ~ k), definition, remainingTransform);
If you click the FeatureScript notices button it will flyout a console output on the bottom of the screen If you toggle on Monitoring you can see the result of the last committed script
