Simple shape (in concept) - Y adapter
alex_wiebealex_wiebe Member Posts: 4
I'm starting to really like OnShape - have designed a number of boxes, basic pieces. Now I'm stumped again on a fairly simple idea to conceptualize: Y shaped hose adapter.
I made a hose adapter using the loft tool to change from one shape (square) to another (round) - but in this case I'm not changing shape, but rather diverging or splitting a extrusion.
I'm thinking I start by sketching the base tube, then create a couple offset planes on angles up top and sketch the same tube profile.
But now how to extrude up a distance, and then split into 2 extrusions that meet the lofted planes?
Or am I completely thinking wrong.
  • alex_wiebealex_wiebe Member Posts: 4
    Ok - I get what you're explain in principle, but I'm missing something. If I try to loft a solid from the end of the cylinder to the circle on the sketch that is offset, it forms a bad-brown hour glass type shape, which disappears if I set both ends to "Normal to Profile". If I select Surface, it will loft, but then I can't mirror and the shape is partially hollowed out.
    https://cad.onshape.com/documents/2be09e87958bc03983b7512b/w/8d417b0b7b149c74c83b9308/e/0b4cd91cbbdc0305cc532406
    I banged something into existence - thanks!
    I don't actually want the loft to curve, so I've left the ends to default.
    But I do want the top ends to be perpendicular to the tubes and not parallel to the bottom. So on to the next learning curve!
