What is this symbol in my model?
saurabh_tewari
Member Posts: 4 ✭
Hello everyone, I was working on an assembly and an odd symbol appeared at some point that I do not understand. What does it denote? How can I get rid of it? Any help is appreciated!
Are you able to share a link to the document?
Cheers O.S.Business Systems and Configuration Controller
HWM-Water Ltd5
That's two icons, the circular one is a mate connector, the other is an actual mate. K key to hide the former and I believe J key for the other. If I've got that wrong then there's a key list under the help menu.
Cheers Owen S.Business Systems and Configuration Controller
HWM-Water Ltd0 -
Thanks Owen. Hitting J and K caused a whole bunch of mates to show up (and then disappear upon hitting the same key again). But it did not affect this symbol(s) at all. Still a puzzle...owen_sparks said:That's two icons, the circular one is a mate connector, the other is an actual mate. K key to hide the former and I believe J key for the other. If I've got that wrong then there's a key list under the help menu.
Cheers Owen S.
HWM-Water Ltd5 -
Let me know if this works:owen_sparks said:Are you able to share a link to the document?
Cheers O.S.
https://cad.onshape.com/documents/2055b7bbe0537d50a66f28d8/w/66b74cce71bce08908b48791/e/ea59601e431dc935ccdba08c
Hi @saurabh_tewari
I took a look at the link and I don't see the symbol you're talking about:
To me, in your original picture, it looks like a mate connector with a graphical bug (possibly something to do with transparency on the inner part of the mate connector itself). Is this still happening for you? What operating system and browser are you using? Does this page report any problems:
https://cad.onshape.com/check ?
Jake Rosenfeld - Modeling Team0 -
Hi, sorry about the delay. Yes, it is still there but since it is absent in your system, I am ok with it. The compatibility check looks good for my browser (Firefox on Windows 7).Jake_Rosenfeld said:Hi @saurabh_tewari
