Unable to enclose these surfaces
Hi all
I'll have to admit that I'm at the beginning of understanding surfaces and I'm struggling in how to enclose what I created here:
https://cad.onshape.com/documents/69acee4fe669c0504dfd9991/w/c1f67ffa6cdd45254e0f9700/e/0e86bfbbe5d6a88b3b237ac2
The help states that I have to select all surfaces/solids that form a enclosed region to convert it into a solid. When I do this on my part it doesn't work and just states that the resulting form is not valid.
Please, advises in what I did wrong are highly appreciated
Cheers
Stefan
  • stefan_eichbergerstefan_eichberger Member Posts: 2
    edited March 2018 Answer ✓
    Good god , I'm very sorry.
    You are right. This was my mistake I guessed when I use 'Fill' that the result will be surface.
    After doing some more tests I figured out why I thought that. All 'Fill's are surfaces until the last fill encloses the shape and then it will be automatically a solid.
    Thanks for the help I'll go and sit in the corner for a while :)
    All good! glad I could help.
