Trying to make a solid of constant width but can't seem to trim the edge bits.
Aidan_Salasin_Deane
Posts: 1 ✭
Need help finishing solid of constant width, was following along with the video below but when he uses the intersect tool in solid works it doesn't seem to work in onshape with the boolean feature.
https://www.youtube.com/watch?v=MaFafTmfMkg
https://www.youtube.com/watch?v=MaFafTmfMkg 0
don't know why that guy makes this body so, i would made 4 balls with centers in the vertices of pyramid and find intersection
https://cad.onshape.com/documents/f10204aa10d2bbfffb901440/w/2b4f74ba225afb77672c06aa/e/eaa1a024a4c549350ae791d2
@Aidan_Salasin_Deane
If you post a link to your document here, someone can see why it's not working. I watched the video and everything should be possible in Onshape. Note that when he's intersecting the circular caps, he's doing the intersection 2 caps at a time, not all 3 or 4 together.Jake Rosenfeld - Modeling Team0
