How can I import a Solidworks drawing template?
George_Smith
Member Posts: 2 PRO
I have a saved Solidworks drawing template (.dwgdot file). How can I import this into Onshape and save for future use?
I think you mean .DRWDOT. One way I can think of is saving it as DWG from SW and then import into your document in Onshape. You can then export it as DWT to be used as template. See "Exporting a drawing to a template" in help - https://cad.onshape.com/help/#templates-custom.htm?Highlight=upload.
Please see the help for custom templates here: https://cad.onshape.com/help/#templates-custom.htm?Highlight=custom template
The section you want to follow is titled: Using traditional CAD drawings as templates in Onshape
This basically helps you to marry the look of your SolidWorks drawing with the behavior of a proper Onshape drawing.
This is also another helpful reference: https://learn.onshape.com/courses/best-practices-for-creating-native-onshape-drawing-templates?returnTo=/learn/article/best-practices-for-creating-native-onshape-drawing-templates2 -
