Contersink bore in a sheet metal part
rafał_korbiel
Member Posts: 2 ✭
Hello.
I've got a problem with countersink bore in a sheet metal part. It doesn't work.
When I try to make this type of hole Onshape make only simple drilled bore.
Best regards
Rafał Korbiel
Best regards
Rafał Korbiel
First you need to create a "Finish sheet metal model" feature
Actually, you can't create other features like an extrude cut with less depth than the sheet metal thickness.
Here are an example of a cut and a hole before and after the finish sheet metal part feature
https://cad.onshape.com/documents/308e0dc5a2e141fb7522630a/w/f68ffd7e9f1648fa3ff50a27/e/4cf92e27b75cbfe7419ea243
Un saludo,
Partner de PTC - Onshape Averigua a quién conocemos en común7
This isn't available yet but there is an improvement request.
https://forum.onshape.com/discussion/7312/countersunk-holes-in-the-sheet-metal-flat-pattern0 -
Un saludo,
