error on set attribute
papawopapawo Member, Developers Posts: 206 PRO
edited May 2018 in FeatureScript
i have query 1(featurelist) and query 2 (face);
if i choose query1, set attribute "entities" : entity,;
if i choose query2, set attribute"entities" : entity,
why do i get error when i choose query2? error is "@setAttribute: CANNOT_RESOLVE_ENTITIES"
  • papawopapawo Member, Developers Posts: 206 PRO
    i found out that if the other query is nothing , it gives me error.
    so how should i do it then? user need to choose either of the 2 query.
    solve it...i put else in the code...
    im  getting an error..when i tried to use the last code.
    im still getting error
    precondition of setattribute failed (definition entities is query)
    In the code you sent me, if `definition.userSelFaces` is false, the "entities" variable is never set, so you are passing undefined into `setAttribute`.
    In cases like this, using `println` to print out the values of certain variables at certain points in your code can be a very useful debugging technique.
