error on set attribute
papawo
Member, Developers Posts: 206 PRO
i have query 1(featurelist) and query 2 (face);
if i choose query1, set attribute "entities" : entity,;
if i choose query2, set attribute"entities" : entity,
why do i get error when i choose query2? error is "@setAttribute: CANNOT_RESOLVE_ENTITIES"
You could do something like:
if (size(evaluateQuery(context, query2)) > 0) { // set attribute on query 2 } else { // behavior if query 2 is empty }or eventry { // set attribute on query 2 } catch { // behavior if query 2 is empty }
I don't fully understand your question, but it should be simple to check whether query 2 has any content at the very beginning of your feature and just fail out if it doesn't.
Typically when we write our features internally, we use the following pattern to make sure Querys have actually been selected:// In the precondition annotation { "Name" : "Face to annotate" } definition.query2 is Query; // At the beginning of the feature body if (size(evalauteQuery(context, definition.query2)) == 0) { // First parameter is the error to throw, second parameter is the // field that should be highlighted red in the feature dialog. throw regenError("Select face to annotate.", ["query2"]); }
Jake Rosenfeld - Modeling Team5
i found out that if the other query is nothing , it gives me error.
so how should i do it then? user need to choose either of the 2 query.
solve it...i put else in the code...1
Jake Rosenfeld - Modeling Team5 -
im getting an error..when i tried to use the last code.
im still getting error
precondition of setattribute failed (definition entities is query)0 -
In the code you sent me, if `definition.userSelFaces` is false, the "entities" variable is never set, so you are passing undefined into `setAttribute`.
In cases like this, using `println` to print out the values of certain variables at certain points in your code can be a very useful debugging technique.Jake Rosenfeld - Modeling Team0
