How to replicate holes around a simple ring?
going_along
Member Posts: 29 ✭✭
I have a hole in the side of a ring and I want to replicate that hole 5 times (ie every 72deg).
I choose the circular pattern tool - right?
How do I select the hole?
How do I select the rotation axis?
The way I am going about it the only thing I can select is the entire part.
Hi.
You're nearly there.
You need to change the drop down box from "part pattern" to "face pattern".
Like this:-
You'll then be able to select the inside cylindrical face of the hole for the "faces to pattern" input field.
For the rotation axis Onshape is pretty flexible, you can select any edge or face that has the required centre and orientation. So inside cylindrical face of the ring, outside face, top face, bottom face, circular edge, all should be just fine.
Link to example file used above:-
https://cad.onshape.com/documents/97b1f804174173b0a04b158a/w/cfd6736b76488fc61d51ba0d/e/8952896f51a6d9a326f3a588
Help Files:-
clicky
You could also use feature pattern instead of face pattern, either is good here.
Hope that helps,
Owen S.Business Systems and Configuration Controller
HWM-Water Ltd5 -
No worries we've all been there. 😀
Cheers,
HWM-Water Ltd5
Hi.
Like this:-
Help Files:-
clicky
Hope that helps,
HWM-Water Ltd5 -
Thank you for the great answer. I entirely missed the Pattern Selection Box - stupid.
1 -
Cheers,
HWM-Water Ltd5
