Work With Bend Deduction / Bend Allowence in Sheet Metal?
Hello, is there a way to work bending with bending allowance and bending deduction instead of using K Factor?
We have bending tables for all tools, materials and sheet thicknesses. So it can be bent to 0.1mm tolerance.
With the K factor, this is only an approximation and more suitable for locksmiths.
Google is responsible for the bad translation
Gruß Hobie
Gruß Hobie
lana Onshape Employees Posts: 743
@hobie_smith
This functionality is not currently available. Several users have expressed interest in this option, it is on our radar.6
Ich hoffe diese Funktion ist bald verfügbar.
I have made a custom feature here that does what you want.
Please give feedback.
Can you send me the feature?
@mbartlett21
has the link to feature in the word 'here' above
Hello, I do not quite understand how the deduction is calculated. We, our machines and software calculate so: Outside dimensions + outside dimensions - deduction. I give here for example 1.66 for a sheet with a thickness of 0.95mm, I can not get the result as if I count it in the calculator. As the value increases, the stretched length would need to be shorter, not longer.
Sorry, I have the bend deduction calculated wrong :-(
The bend allowance should work fine though.
EDIT: Now fixed: Please update to version 6.1
