thickness of a cuboid
After selecting 2 vertex to create cuboid,
How can I get the cuboid thickness by query?
Jake_Rosenfeld Moderator, Onshape Employees, Developers Posts: 1,646
You could use evDistance between two of the faces, but since fCuboid is axis-aligned you could skip the geometry creation and just check the difference of the x, y, or z components of the two vertices.Jake Rosenfeld - Modeling Team5
Query the largest area?
Ive seen qLargest function but dont know how to use it. Am I in the right track or is there something simple to accomplish this.
By getting the 2 vertices and checking the diff of the x,y,z , how would I know that its giving me the thickness?
