Need to change extrusion height of 16 different parts with a Variable or equation
paul_bartlett
Member Posts: 98 ✭✭
This is the part I am referring to https://cad.onshape.com/documents/19ccedfa79bcaae737fc2b78/w/57ef42aa3da09539b7ab6acb/e/595ed0d6e4e6dca34a193ead
I extruded each segment one at a time as they need to be different parts. I wold like to change the extruded height of all of them at one time. Is there a way?
You could extrude 1 part, then pattern it 16 times. That way you can edit the one extrude, and it will change all the parts. Make sure the pattern is set to 'New' so it creates new parts instead of merging them with the existing one.
5
Variables?Business Systems and Configuration Controller
HWM-Water Ltd0 -
Do you mean I have to create 16 Variables or is there a way to include all 16 parts in one Variable?0
You can include all 16 parts in a variable but of course all 16 parts will extrude that single variable's amount/distance. Just copy/paste your #Height variable in to each extrude distance.0
5 -
Here you can see a sample with a few variables:
Take a look to the document
https://cad.onshape.com/documents/35e4812de6a34ebfa52c6115/w/3eab0c225f16cca810cee198/e/26f6ce5a49f114f6be25d6ab
Un saludo,
Partner de PTC - Onshape Averigua a quién conocemos en común3 -
Nice job...0
Well, actually it is one of the simpliest weldments I have ever done ;-)
Un saludo,
Partner de PTC - Onshape Averigua a quién conocemos en común1 -
Extruding one part then pattern as new was just what I was looking for. Worked perfect. Many Thanks Jon0
