3D point
alberto_porras
                    Member Posts: 2 EDU
                    Hi,
I would like to know if it's possible to create a 3D point by coordinates.
Sometimes it is useful to create geometry from a specific point, thus I need a 3D point.
Thanks a lot in advance
The more direct path would be to use featurescript. Here's an example script by @dave_cowden. It requires at least 2 points to be created, but it could be edited to allow an individual point.
https://cad.onshape.com/documents/502108ab33bd9af500b73c1a/w/68f73347f084d40c31271b24/e/5c9b644bfa74fd744d6bf626
https://cad.onshape.com/documents/05e61f73d88c30ebe9e3baf8/w/6e72e2b08afb63489da10bdf/e/a7fc29bda73abe3a05aec06b
annotation { "Feature Type Name" : "3D Point" } export const threePoint = defineFeature(function(context is Context, id is Id, definition is map) precondition { annotation { "Name" : "X" } isLength(definition.x, LENGTH_BOUNDS); annotation { "Name" : "Y" } isLength(definition.y, LENGTH_BOUNDS); annotation { "Name" : "Z" } isLength(definition.z, LENGTH_BOUNDS); } { opPoint(context, id + "point", { "point" : vector(definition.x, definition.y, definition.z) }); });TVP, Onshape R&D
I would propose this option to work with multy-edge paths as well.
UPD: and possibly when you will work on Intersection option you can make a subfeature which would create intersection wire body from sets of faces, which is also often needed
Here is a point FS: https://cad.onshape.com/documents/576d1e60c6cb90985345ac37
It supports projection, coordinates,and intersection
Try this feature: https://cad.onshape.com/documents/84d939daceef6a928b8abcba
Try the new version 2.2, which adds localizedInFaces compatibility (With it set to true, it takes faces as input, which is cool)
Done
I can also add it for multiple points if you want
Try this other feature of mine (Delete Part): https://cad.onshape.com/documents/33416d14c3930276fd8453fc
Multiple Points along path: DONE!
on opBoolean Plus, can you make it work for surfaces with internal boundaries the same way that Find Intersection does. Either that, or maybe allow Find Intersection to generate either a point OR curve(s)?
For that matter, the single/multi workflow seems to be pretty redundant for all the input types. For along and coordinate, if there is just one input, it's a single. If there is more than one, it's a multi. Same goes for projection. If one vertex is selected, it's a single. If more than one, it's a multi.
The only "single" input left is intersection. That is currently limited to single points. 3 surfaces with 2 points of intersection currently fails. If possible, try to account for multiple intersections. I would also add support for intersecting curves with surfaces and again try to account for possible multiple intersection points. All these fringe cases are what held up my progress when trying to develop this FS myself, but if you have the time then these additions would make for a lot of versatility
Last, but not least, maybe add an "equal split" option for along curve to create N points equally spaced along a curve, either with or without endpoints.
All right, my wish list is over
I did the multi coordinate input like it is, so it would allow copy-pasting from excel or csv
What find intersection does is boolean the two surfaces without any holes, then uses evDistance to find the intersection, as that is the only way i know to get the intersection of a curve and a face.
I notice however that the 'Project' option projects to point on the surface that is normal to the surface.
In my case, i just need the point directly under the point (normal to the sketch containing the seed point).
Do you have an updated version of this that offers this option?
Thank you
Edit: Nope, I lied. Both 3D Point and Find Intersection only take surfaces inputs. I guess the way around that would be to generate a couple surfaces whose intersection is your green line. Seems like a lot of work though for what seems like it should be a simple operation. @mbartlett21, maybe you can add a "projection direction" option that accepts a plane, planar surface, or linear edge/sketch/curve? Nothing selected = projected normal to target surface.
@philip_thomas
Done!
It now has projection direction that can be specified (it uses opExtrude internally)
