Import Cad assemblies
junhyeok_ahn
Member Posts: 1 ✭
Hello, I am trying to import cad assembly files to onshape.
I followed instruction of how to import cad file.
So I imported zip file but it shows below screens.
I know it will take some time to be translated but how do I know whether it is failed or succeed?
Is the name of the ZIP file the same as the name of the top level assembly?
Is there any folder structure in the ZIP file? There shouldn't be any extra directories in the ZIP file.
Also, what was it created with?
If the file is translating, there should be a notification (Unless you deleted the notification)
