Importing into OneRender
tattwood
tattwood Member Posts: 2 PRO
edited July 2018 in Community Support
Can anyone help...
For some reason when I import into OneRender my assemblies do not stay together, like below:
Is there something I'm missing?
Many thanks!
  • jan_gaare
    jan_gaare Member Posts: 7 PRO
    If you import form solidworks, it needs to be the zip package file  you import. Jan
  • isaac_ruiz
    isaac_ruiz Member Posts: 2 ✭
    Dear @tattwood ,
    Would you mind sharing your document to info@onerender.com?
    We'll take a look if something is wrong.
    Thank you.
  • tattwood
    Thank you very much for your replies, however I think I was able to solve this problem.
    It seems that there were too few mate connectors, so even though it looked right in the assembly, parts were able to move and explode away from each other when imported.
    Once the mate connectors had been improved this problem seemed to right itself.
