Add part to studio or assembly
joshua_foxworth
joshua_foxworth Member, Developers Posts: 19 ✭
I have a partner platform where the user will be able to copy a part from one document to an assembly in another. I can't quite seem to figure out the correct process to do this through the APIs. Is this just adding a feature?
  • D8_Starpac
    D8_Starpac Member Posts: 49 ✭✭
    You can just copy the part to clipboard and paste tab where the assembly file is located and then insert the part.
  • Jake_Rosenfeld
    Jake_Rosenfeld Moderator, Onshape Employees, Developers Posts: 1,646 image
    @joshua_foxworth
    Do you want the assembly reference to be made to the original part (parametrically), or do you want to copy the part studio into another document and not have the new update with the old?
  • billy2
    @joshua_foxworth
    because you're accessing another document to a part, you have to change the 'w' in the address to a 'v' and get the version id.
    you can not access work spaces in other documents in either the UI or the API.
    The api calls work the same as 'w' or 'v', just get the correct version id for the part studio/part if calling from another document.
