Derivated beahviour
fma
fma Member Posts: 87 ✭✭
Hi,
I inserted a part from a Part Studio in an Assembly. Then, I derivated that Part, and modified it. Now I see that the initial part, inserted in the Assembly, is also modified. Why? I though that the initial Part would remain untouched...
Thanks,
  • philip_thomas
    philip_thomas Member, Moderator, Onshape Employees, Developers Posts: 1,381 image
    @fma - we are a little confused, your initial expectation is the correct one - the derived part (and any modifications) have zero effect on the parent.
    Please feel free to post a link or submit a support ticket and we will be happy to look at it.
    Philip Thomas - Onshape
  • fma
    Well, I started to make a simple example, but it works.
    So I removed the part from my assembly, then re-inserted it, and it now works fine. Don't know what happened, I may have made a mistake, but I don't understand how.
    Anyway, thanks for your answer.
  • philip_thomas
    @fma - not a problem. If i had to guess, i would say that you had accidentally used the derived part in your assembly. :)
