Don't match full string regex
MBartlett21MBartlett21 Member, OS Professional, Developers Posts: 2,063 ✭✭✭✭✭
How do i not match a full string in regex (I want to extract numbers out of it)
  • mthiesmeyermthiesmeyer Onshape Employees Posts: 115 image
    Hi @mbartlett21
    Perhaps add an example string that you would like to match and some examples that should not match? Are you saying you would like a regex that matches any string that contains at least one number? Or contains all numbers? Or something else?
    @mthiesmeyer
    I would like a function to evaluate a string (like javascript eval()).
    Example string: "x^2 + y^0.5".
    I was wanting to use something like this to get the numbers in the string
    @ilya_baran
    How does the Expression type work?
  • ilya_baranilya_baran Onshape Employees, Developers, HDM Posts: 1,248 image
    It's all defined in that feature studio.  Basically, the idea is that an Expression is just a lambda function, say of one variable, t.  The operators are overloaded for Expression types so that when you, for example, add two Expressions, the result is a function that evaluates the two functions and returns their sum.  Constants are just turned into functions that return that constant, and t_ is the identity function.  So when you write t_ + 3, you get a function that returns 3 plus its argument.  More complicated expressions also just turn into functions that evaluate them.
    @ilya_baran
    Is it faster evaluating through a few functions to get the value, or would functions that returned reverse polish notation be faster?
    Neither will be terribly fast.  I'm not sure which is faster -- you'd have to measure.  I have a vague plan of using operator/function overloading to construct an expression tree in FS and have builtin functions compile it using LLVM, but that's far out.
    What is LLVM?
    Ilya, would there be any way to have an input like
    annotation { "Name" : "Input", "Variables" : ["var1","var1"]}
    definition.input is Expression;
    Here is my evalExpression script now (it first splits the tokens, turns that to Reverse Polish Notation, then evaluates it. It also allows contxts and lists of variables to be input, like x, y, etc.):
    https://cad.onshape.com/documents/429fd7dda5f0fdb93833a34a
