Fillet Invalid Geometry
joshua_sapers
Member Posts: 1 ✭
Hi,
I am trying to fillet a rectangle; however, the width of the rectangle does not support a .1in fillet. When I try to insert a fillet, it throws me a "The current fillet radius produces invalid geometry". Is there a way to change the fillet radius without adding one first?
Thanks,
Josh
Thanks,
Josh
Try selecting the two adjacent edges instead of clicking on the corner. Are you still able to do a sketch fillet?joshua_sapers said:Hi,
Thanks,
Josh2
Thanks,
Josh2 -
A workaround I found is to make a larger sketch next to the one you actually want to fillet then fillet a corner of the larger sketch and change the fillet size there. Now delete your larger sketch and your fillet should work on the actual geometry.0
