Project to Surface
 Stuart_Tod
                    Member Posts: 65 PRO
Stuart_Tod
                    I've used the search function in the hope of finding an answer, but without any luck. So, can I project a 2-D sketch onto an underlying (curved) surface to provide a 3-D 'path'?
I'm trying to project sketch 5 in this open document onto the curved surface of Part 1 ( https://cad.onshape.com/documents/ef2e97eee4cf47578ba6a15d/w/d3c8a9e635194cf19de53fae )
And, if we can, when are we going to get a 'path' mate to go with the others? Please!
Stuart
Stuart
2
             nav
                            Member Posts: 258 ✭✭✭✭
                    Hi @stuart_tod , I believe this feature is not yet available in OS, you can`t project sketches to curved surfaces (yet). nav
 Nico
 Nicolas Ariza V.
 Indaer -- Aircraft Lifecycle Solutions6
Nico
Thanks - will have to hope this is on the OS wish list, and somewhere near the top (along with 'Path Mate' !
Stuart
One possibility: use same sketches which created the "curved surface" you refer to in your post to make dummy target solid. Now extrude your "2-D sketch" as a surface, use that surface to split the dummy solid, use resulting edges as 3D curves, hide dummy solid (I said it wasn't pretty) ...
.......it's five o'clock on a Friday afternoon here....I think my head just exploded halfway through your workaround. That'll be something for me to try on Monday!
Thanks
Stuart
That's nothing, it's 0400 Saturday morning here (don't ask!)
I shared a model I was looking at for Raino, I hacked it to do a quick proof of concept (not as ugly in practice as my description made it sound)
it's called "Loft testing - Raino" and the tab which demonstrates the workaround is called "Project Sketch to Solid" The last two features constitute the workaround.
Nico
Anyways, projecting a spline onto a surface; has that gotten anywhere?
