Export .stl from sheet metal flat?
RobotMan2006
Member Posts: 3 ✭
I'd like to be able to export an .stl file from the sheet metal flat view so I can 3d print a foldable design. Right now I can export a .dxf file and create a new part by extruding it but that seems like unnecessary extra steps. Anyone else try to do this? Is there a better way?
Insert the flat pattern into an assembly then export the assembly2
This lets you do it in 2 clicks:
https://cad.onshape.com/documents/d075777b23239493791a6871/w/397dabbf4f532daf03a395c5/e/dba9566c2dda32a29752e76b
