Common Parts
PAH
Member Posts: 18 EDU
Hello,
Our FRC team would like to try and use OnShape for our Robot. We found 8020 profiles in the community space and made a copy. To make many different lengths of the profile is there a way to just change one number and create a part? We found the one file with the profile. Do we just need to duplicate this file for each different length?
1515 x20"
1515 x5"
1515 x6.5"
1515 x20"
1515 x5"
1515 x6.5"
@PAH
You can configure the length of your extrusion, or you can use either of these beam features to create and extrude the profiles for you:
Neil Cooke's: https://cad.onshape.com/documents/e15c2c668d138f01242d0c80
Mine: https://cad.onshape.com/documents/cbcb5406bdf8ec15703a9e9e
Thank you for trying to help me. You go cart frame is the right Idea. I just do not understand the way it was created. It is far more advanced that I expected. I just want an easy way for high school students (grade 9-12) can make a robot without recreating every part. We will use only one extruded aluminum profile. I just want them to determine all the lengths so they can layout the entire robot. It needs to be simple for high school students to grasp and me!0
@PAH
First, you will need a sketch with lines corresponding to the beam or beams you want to make.
You can then run either FeatureScript on the line, choosing the profile you want.0
