Mesh Point, Selection
famadorian
Member Posts: 390 ✭✭✭
I've imported a mesh and I want to select a point. Normally, I have no problems selecting the points I want, but sometimes there are points which just can't be selected
Like here, I'm able to select the upper point, but the lower point I'm not able to click on.
Any pointers as to what I can try or why it doesn't work?;)
Can you try using select other (`)0
Either that or there's something in the way, sketch, plane etc. I'd hide everything except the mesh and then start selecting points.
HWM-Water Ltd0 -
Jake Rosenfeld - Modeling Team0
Here's a video.owen_sparks said:Either that or there's something in the way, sketch, plane etc. I'd hide everything except the mesh and then start selecting points.
It looks like the other points I'm trying to select are "behind" a polygon, but shouldn't I be able to select the intersection between a line and a polygon?
https://drive.google.com/file/d/19TOtDg7vW638o95jE46KF3Yiwjqany2L/view?usp=sharing
eeeeek! you have 1 part, 6 surfaces and 1574 separate meshes there. I'm not surprised something is blocking something else.O.S.Business Systems and Configuration Controller
HWM-Water Ltd0 -
1574 separate meshes? I imported this OBJ file and it's one single mesh?owen_sparks said:eeeeek! you have 1 part, 6 surfaces and 1574 separate meshes there. I'm not surprised something is blocking something else.O.S.0 -
Look at your file in the place I've indicated below:-
HWM-Water Ltd0
