How to Create a set of Sketch & Feature that are available to be imported/insert into a Part Studio
patrick_farley
Member Posts: 37 ✭✭
Hi,
i am trying to make a bank of avionic instrument drill out and be able to use them on a custom instrument panel
right know i am only able to make a list of sketch and copy / paste them on the new part. i cannot have any feature save.
I try the derived feature, but, I cannot change the location after the insert is made.
Is there a way that i could make a set/bank of Sketch with Feature, and easilly use those to insert into a new part
In the bottom of the picture i show my set of drill out instrument in sketch only, but they are missing all the feature (chamfer)
In the top of the picture, i show what the real drill out for this instrument would be. (chamfer)
Thanks
Pat F
Thanks
Pat F
Optionspatrick_farley Member Posts: 37 ✭✭Thanks Criss, your idea gave me part of the answer.i did finally draw a negative of my cut out needed, and i could not union all the part together because the part were not touching, i included you idea of a face plate connecting all my part together and VOILA....So i insert point on my instrument panel, and insert the mate connector (i redraw the instrument panel on the top plane instead of the front plane to get the mate correctly insert without the need to realign them) on a sketch.i then create a assembly, and insert the instrument panel, the instrument, then i did a in context edit of the instrument panel then i did a boolean subtract and there it was.Thanks a lot for your idea, it help me find my solutionPat F0
Optionsowen_sparks Member, Developers Posts: 2,660 PROHi.Sorry I'm late.I use a similar method on occasion.First create a library document containing a bunch of solid parts describing the cutouts required.Then just derive them into the part target studio, "transform by mate connector" into place, and then use the boolean tool to make the cutout. (No assembly or ICE required.)I'd intended to make a custom feature with a pick list of hole types that you could just point to a sketch entity but never got round to it. Thanks for the nudge, I ought to finish that...Cheers, Owen S,Business Systems and Configuration Controller
HWM-Water Ltd5
https://cad.onshape.com/help/Content/transform.htm
i don't want to move or rotate or translate a Part.
I would like to copy only the sketch, and feature of a part (not the part itself) onto another one.
i would like to desing a instrument panel. (a full sheet of metal) from the shape of a specific airplane
Then using a bank (set of cut out) of all the possible instrument. insert the cut out to the correct location
I try to create a Negative of the holes, (to be able to create a Boolean Subtract) but i cannot create a single part, as the hole are not touching together.
I would have to transform the 5 parts individually
This bank/set idea is so i don't have to redraw the hole location and chamfer for each instrument panel that i make, only the position would be left to do
Sheet of metal without hole:
Bank of instrument cut out:
Hole made on the instrument panel:
Thanks
Pat Farley
Onshape, Inc.
https://cad.onshape.com/documents/e97782e2780ed83fd9c3e093/w/f25a3a806831992d05ca55b2/e/cf752c5b58e57518a5338943
Please see this FS for something like what you want to do:
https://cad.onshape.com/documents/389762cf46ca2a3fcc9d4ad9
