Is There a Way To Set Distance Between Features With Curve Pattern?
larry_hawes
Member Posts: 478 PRO
in General
I see where the number of instances can be set but not distance between. nor an end point nor any other truly useful feature. Must be missing something...
Optionskonstantin_shiriazdanov Member Posts: 1,221 ✭✭✭✭✭once the FS is written by someone it fully capable modeling feature, you don't need to read the code to be able to use it. just select it after clicking (+) button in the top right corner of OS part studio interface, while being in the document of feature definition and add it to your toolbar
5 -
Optionslarry_hawes Member Posts: 478 PROAH HA!! Never used a FS before and after adding it to the tool bar I see it behaves like any other feature dbx. Thanks VERY much for the help...
It appears as though deleting the original gets me the spacing I'm looking for and regenerates properly.0
Is there a field one can fill out for such a simple task? Like number of instances and distance between?
Or maybe a better question might be why is this feature included in OS if those parameters aren't included? Of what possible use could it be without being able to specify distance between features?
